99 Sebring Convertable directionals not working
Old Apr 25, 2010 | 05:41 PM
99SebringNH's Avatar
Default 99 Sebring Convertable directionals not working
Ok so heres the deal I just bought a 99 Sebring convertable for the summer and the directionals don't work.I checked the fuse and it is ok and all the lights work when turned but nothing from either directional.Any and all help will be greatly appreciated.
thanks
Bob
Old Apr 26, 2010 | 02:38 PM
Check the bulbs again. The bulbs for the turn signals have two filaments. Just because the bulb lights when you turn on the running lights doesn't mean that the turn signal filament is working.
If it's not that, then the problem may be in the switch or the wiring or a ground.
Old May 5, 2010 | 06:29 PM
arnehoff's Avatar
Besides bulbs, you may have a turn signal flasher out. Many people are also changing to LED bulbs also. LED bulbs are not compatible with the stock flasher because there is not enough current draw. If that is the case, change the flasher to an LED compatible one.
andrew61
Nov 8, 2012 10:05 AM
dpbrowne
Jan 24, 2011 04:10 PM
newbe
Nov 18, 2007 10:19 AM
PIMPINPHIL
Oct 17, 2007 05:29 AM
ace
Nov 18, 2005 12:13 AM
