99 sebring jxi won't start
Old May 28, 2018 | 04:33 PM
REBEL59's Avatar
Mine is pretty much orig. other than fuel filter, exhaust flex pipes, alternator and Valve cover gaskets and plug well seals. But plugs, cap, rotor are insprected annually! Plugs for the rear are a BUMMER to do!Darned manifold design for low hoodline!
Old Jun 13, 2018 | 10:47 PM
sasori563's Avatar
Ok so I finally have an update, I got the car to run by outing a couple zip ties on the end of a worn out vacuum lone fitting, their ends the good news. Now for the bad news.
I assume I know the fix for this next issue but I want to make sure theirs not something else to check while I'm under it. I have not been able to replace the catalytic converter yet because the bolts are hard to reach and rounded off as well, this matters because the cat has a large hole in it. Second is the 02 sensors, the old sensors are seized in place and even with a torch they wouldn't break loose.
I plugged in the new 02 sensors into the harness but since i cant get the old sensor unscrewed i zip tied the new sensors up out of the way until I can finally replace the cat. believe these 2 issues are the combined are the cause of a severe loss of power and a very rich fuel mixture causing a flame to come out of the cat hole.
Old Jun 15, 2018 | 10:01 AM
sasori563's Avatar
I feel like my last update wasn't clear at all, I'm trying to verify if the hole in the cat, combined with the o2 sensor being plugged in but not installed in the cat could cause the car to spit flame from the hole and have severely reduced power
Old Jun 15, 2018 | 11:34 AM
Do you imagine that plugging in an oxygen sensor to the computer but NOT installing it in the exhaust stream would NOT cause problems of driveability? Are you serious?
Old Jun 15, 2018 | 11:36 AM
  #15
sasori563's Avatar
I know it will cause into run rough, but I had to do the same to my old eclipse and never had a flame issue. If I leave them unplugged it wont start or idle at all though
Old Jun 15, 2018 | 05:28 PM
  #16
Did your old Eclipse have a hole in the cat?
Old Jun 15, 2018 | 05:31 PM
  #17
sasori563's Avatar
No it didn't but it also never had the flame issue, the old 02 sensors were frozen in so badly I couldn't get them out so I plugged in New sensors and zip ties them up outa the way, it ran rough but it did run, that's why I'm wondering if doing the same thing to the same while it does have the hole is possibly the cause of the flames
Old Jun 15, 2018 | 10:25 PM
  #18
With the sensors not operating in the exhaust stream where they belong, it could be that the computer is thinking that the engine is running very lean and is pouring gasoline in there to the point that raw fuel is hitting the converter and who knows what is going on there. The system was never intended to run like that so anything might be going on. I don't understand how you would know that you didn't have a flame inside the cat on your eclipse if there was no hole to see inside.
Old Jun 21, 2018 | 10:54 PM
  #19
CarComp's Avatar
Just FYI, these cars absolutely will not run if there is any moisture anywhere in the distributor / ignition / wires and stuff. I went through a deep puddle once with a strong running car. Died and wouldn’t start for almost a week (cold weather). Has it been sitting anywhere collecting moisture / lots of dew / rain / driven through puddles?
possible test would be to use a space heater and get the top right side of the engine (distributor area) really hot and see if your problems magically vanish.
Jimdec1
Jul 1, 2013 05:47 PM
smokie44
Oct 20, 2011 09:40 PM
PSD4life
Sep 27, 2011 05:22 AM
jaycarr
Sep 8, 2009 08:49 PM
bobp53916
Jul 17, 2007 12:23 AM
