accessing rear spark plugs
Old Dec 1, 2023 | 10:26 PM
dcheitel's Avatar
Default accessing rear spark plugs
i have a 2006 Sebring convertible 2.7L. I have recently needed to change one of the coil on plug packs and have gone ahead and changed 5 of the 6. the one that I cant seem to access is cylinder 5 which is rear towards driver side. there is what seems to be a pcv or some type of line runing over that coil pack that seems to be a hard line but I cant see how to remove it or get around it. any tips?
Thanks much
Old Dec 2, 2023 | 09:14 PM
sota's Avatar
it's not a hard line, but a rubber line that's gotten hard with age. carefully use a pick and loosen the hose around the fitting and you should be able to pry it off, and rotate it out of the way.
Old Dec 5, 2023 | 10:11 PM
CanadianSebringJR's Avatar
move to the passenger side front wheel and stand infront of it, grab yourself a 1/4 ratchet and the appropriate socket/adapter. reach in behind the intake and unbolt it. ive done it to change plugs many times over the years. a 3/8 drive will not fit back there, dont try, theres a hump in the firewall in that spot. get ready to rub your knuckles on some insulation though.
aggiejet
Aug 19, 2013 02:10 AM
unholyfire
Jan 23, 2011 10:51 PM
jameslee522
Dec 15, 2007 09:55 AM
jameslee522
Nov 24, 2007 12:59 PM
300Cno1
Sep 4, 2005 05:06 PM
