Alignment after stut and upper control fix
Old Dec 6, 2017 | 07:52 PM
purplepuller's Avatar
Default Alignment after stut and upper control fix
Just replaced Front Struts and Upper control Arms on 2004 Sebring. Do I need to get an alignment?
Old Dec 7, 2017 | 02:33 PM
REBEL59's Avatar
In a word...YES, unless you want to continually check tires for signs of abnormal wear for the next few thousand miles.
Old Dec 7, 2017 | 07:06 PM
Just wandering because the strut and upper control arm are just unbolt and bolt in new stuff. not messing around with any adjustable parts for Caster Camber. Anyways car is not as noisy as it was up front.
Old Dec 7, 2017 | 07:11 PM
What I mean is no noise at all in front end, but car is noisy because put on studded winter tires.
Old Dec 8, 2017 | 06:46 PM
Lack of alignment doesn't cause noises, it causes abnormal tire wear. You can't diagnose misalignment by listening to the car. The front end can get out of alignment from general wear and tear, hitting potholes in the road, etc. If it was out of alignment before your work it won't be any better now. The only way to know that it is or is not aligned properly is to have it checked on an alignment machine. Monitoring tire wear carefully is important, but by the time it shows up as a wear pattern on the tires, you've chewed through a lot of rubber unnecessarily.
Eric Merritt
Jun 5, 2017 09:35 AM
darkcild101
Apr 28, 2015 12:32 PM
mikeso_81
Dec 14, 2014 12:35 AM
2003sebring
Feb 13, 2012 07:07 PM
ejmorgan60
Dec 22, 2010 03:24 PM
