Battery/Voltage Light
Old Dec 2, 2008 | 11:09 AM
dnking's Avatar
Default Battery/Voltage Light
I have a 2004 Sebring with 90K. Issue with battery/voltage light coming on when driving and the odomoter lights & radioflickering. When I shut the car off and turn in back on the light is off and everything fine. A few days later same thing happened. Any ideas on the cause/solution?
Old Dec 2, 2008 | 05:36 PM
Default RE: Battery/Voltage Light
Could be a failing alternator. Could be a loose wire or ground. Might be a loose drive belt. I'd check the wiring first. It's cheap and easy.
The charging voltage is actually controlled by the powertrain control module (engine computer), so if there's a problem there, it may be throwing codes. You might want to see if there are any codes.
Old Dec 3, 2008 | 02:29 PM
irdaneel's Avatar
Start with cleaning your battery terminals. If they have a white scale inside the connection it causes very erratic voltages. It is very difficult to remove, and you may wish to replace instead of cleaning them.
Also, jiggle, wiggle, and shake (gently) all of your wiring harness connectors, especially those mounted to items on the firewall, PDC, and PCM. Moisture is an enemy!
If it continues, pull the alternator and have it tested.
cwuba
Dec 3, 2016 04:39 PM
mech3
Jan 12, 2016 09:49 PM
tmjones
May 27, 2015 10:00 PM
ghmpin
Feb 7, 2010 08:23 PM
1bad300
Apr 18, 2007 03:44 AM
