bypassing factory infinity system
Old Feb 16, 2007 | 02:15 PM
jimustanguitar's Avatar
Default bypassing factory infinity system
i have a 2000 sebring with a factory infinity system. i am trying to install an aftermarket radio, but am unsure how to get around the factory amp. i have been told by a few people that there is a remote turn on and a remote ground, but have not done the research since the12volt started charging. does anybody know how to get my aftermarket head unit up and running wothout running new speaker wires? thanks.
Old Feb 16, 2007 | 03:47 PM
Default RE: bypassing factory infinity system
2000 seabring what??? coupe convertable sedan give me the last 8 of the vin and I will get the wireing colors that u need
Old Feb 16, 2007 | 07:40 PM
here's the last 8... yt220853 i appreciate your help with the wiring. thanks again.
Old Feb 16, 2007 | 10:26 PM
the pic i have attached is what u will need the main part to which u will want to make sure still has power when u install is what i have circled. Go to best buy or a car audio place and get an aftermarket install kit for like 20 bucks it will have the connectors that u plug right into the factory wires so that u dont cut them for later use and easy install. Match wires up with aftermarket plug and away u go. Still use factory amp different head unit. Now on the other hand if u want a new amp then no other choice but to rewire the whole system from each speaker to the amp.
Old Feb 18, 2007 | 12:34 PM
i'm familiar with wiring up kits, i work at an audio shop, we just don't usually help people who have to bypass a factory amp. i hooked up the 12 volt trigger wire correctly from the new radio to the new harness, i just wasn't getting the amp to kick on. so i'll try 12 volts directly to the amp to see what happens. thanks again. i didn't use the power antenna wire accidentally instead of the remote turn on wire either, that is a common mistake.
Old Feb 27, 2007 | 07:22 PM
i've got the remote turn on correct and still can't get the radio to work... do you have the diagrams to show me what wires come out of the factory amp to the speakers so that i can just splice around the amplifier? thanks.
Old Feb 27, 2007 | 10:23 PM
the same pic i uploaded has the inputs and outputs to the amp u are looking for see above
Old Feb 27, 2007 | 10:41 PM
didn't notice, and haven't looked in a while. thanks again you've been a great help. jim
Old Feb 27, 2007 | 11:10 PM
the diagram does not show the outputs from the amplifier to the speakers. this diagram only shows the output from the head unit into the amplifier. do you have the diagram that shows the speaker level output of the amplifier? sorry to bother you again, thanks.
Old Aug 19, 2011 | 08:52 AM
BigRob14450's Avatar
Default Wiring guide for most 199 Chrysler's - hope this helps!
Car Radio Constant 12V+ Wire: Pink
Car Radio Ignition Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Back Strap
Car Stereo Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2″ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Dark Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Dark Blue/Red
Rear Speakers Size: 6 1/2″ Speakers
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Dark Blue/White
Right Rear Speaker Wire (-): Dark Blue/Orange
