A/C Relay location
Old May 31, 2014 | 03:52 AM
Ben Sams's Avatar
Default A/C Relay location
Where the heck is the A/C Relay located at on a 2008 Chrysler Sebring? I found 4 Relays under the hood above the fuse box but I have no idea which ones are which or if there are more Relays located somewhere else. I have searched the internet to no avail. Any help would be greatly appreciated.
Old May 31, 2014 | 08:11 AM
Because there is not onew the TIPM is what controls the clutch or blower motor
Old May 31, 2014 | 11:35 AM
Ben Sams's Avatar
So how do I get the a/c compressor to come on so I can recharge it?
Old May 31, 2014 | 04:22 PM
Usually you can get enough pressure in there to get the compressor to kick in just by connecting the can. May need to turn it upside down and warm the can with your hands a little to dump some fluid in there. If you're that low you've probably got a leak somewhere so you'll just be wasting time and refrigerant by adding refrigerant without dealing with the leak.
Old Apr 3, 2017 | 10:23 PM
SebrigLA's Avatar
Got problem with AC compressor engages but no cold air.
Old Apr 4, 2017 | 10:34 AM
Possible sources of problem:
1. Bad expansion valve
2. Non-functional blend door
3. Control head problem (quite common on 2001 Sebring)
4. Bad receiver-dryer
5. Low on refrigerant
Old Aug 29, 2019 | 10:21 PM
lilchikano16's Avatar
Default Ac problem
When I turn the switch on nothing turns on it doesn't even blow hot air
Old Aug 29, 2019 | 10:59 PM
You might get a response if you told us what kind of car you have, year, model, engine and mileage. You might want to describe the history of the problem and what you have done to try to fix it. You might want to start a new thread with the necessary information rather than jumping into a 5 year old thread.
Old Aug 30, 2019 | 02:38 PM
jtcooks's Avatar
Any information about car, model or year ?
sebringguy
Other
Apr 27, 2019 09:08 AM
Aidan2521
Jun 15, 2018 06:25 PM
Aidan2521
Jun 13, 2018 08:59 PM
andyb2000
Jul 19, 2011 08:38 AM
rastoma
Jun 8, 2011 08:05 PM
