Camshaft position sensor
Old Aug 9, 2007 | 08:16 AM
sumncguy's Avatar
Default Camshaft position sensor
I see alot of replacement being completed for these two sensors. I am currently researching for the possible next steps, once I completed with the fuel system.
My question is, why is everyone replacing the distributor when I see that Autozone carries a replacement for the camshaft position sensor (otherwise known as the sync signal generator) ?
Thanks for the help.
Chris
Old Aug 9, 2007 | 08:17 AM
sumncguy's Avatar
Default RE: Camshaft position sensor
Sorry ... the crankshaft sensor is the second I refer to.
Old Apr 17, 2012 | 07:27 AM
Johnny p.'s Avatar
Default camshaft position sensor
Answer to first question is due to dealership recommedations . It is also a good idea considering the ignition coil is confined in there as well an since a majority of problems with a no spark condition does usually is faulted with the distributor it saves alot of time an trouble from running into future problems ! To answer the question of the crankshaft position sensor ,it has been known for many odd problems when defective an sometimes false signals . Both the camshaft position sensor and crankshaft position sensor send signals to the ecm as timing ,firing , enjectors !
jaek707
Dec 23, 2010 07:25 PM
manshack_one
Dec 13, 2010 06:59 PM
pixsmith
Feb 4, 2009 10:25 AM
dcm1971
Oct 13, 2008 12:10 PM
jjmenard
Sep 6, 2007 05:33 PM
