Car Alarm problem
Old Aug 16, 2015 | 10:54 PM
Mike J's Avatar
Default Car Alarm problem
Hi-
I replaced the battery in my 2003 Sebring & the car alarm went off when I opened the door.I put the key in the ignition & turned it to "on", but the alarm didn't stop. Does anyone know how to turn the alarm off? I do not have a keyless entry. Thanks!
Old Aug 17, 2015 | 10:55 AM
If you have the factory alarm system, your car should be equipped for keyless entry. If your key is gray you have the factory alarm system. If your key is black, then your alarm system is an aftermarket product. You'll need to figure out where that system came from and talk to them about it.
If you have a gray key and the factory alarm system, you are best advised to go to the dealer and get it straightened out and get the proper key fobs to control the system.
Alarm systems are not designed to be easily defeated. It would make them rather useless if they were.
Old Jan 28, 2024 | 04:41 PM
300C's Avatar
i have a 2016 300 c ca't disarm the alarm
Old Jan 28, 2024 | 05:11 PM
use the key fob or lock and unlock the driver door
maintenance
Apr 23, 2015 03:52 PM
passingthrough
Jan 26, 2015 04:16 PM
Wendy Smith
Mar 21, 2014 06:57 PM
size2020
Sep 18, 2010 11:24 AM
Rodneystr
Oct 9, 2007 04:31 PM
