CEL On, Car Is Loud
Old Feb 24, 2009 | 01:50 PM
swimjax's Avatar
Default CEL On, Car Is Loud
2004 Sebring Platinum Series V6
Around 75k miles
This is my parents' car. Mom has been driving it even though something was not right. I noticed when walking up to the car, that it's very loud. I can't tell if it's the engine or something with the exhaust, but I suspect it's the engine. Mom says the car isn't driving any differently. For a while, it was just louder than usual, but recently the CEL came on. I know this could be many things, but just trying to get an idea of what to expect when it gets serviced on Thursday. Any ideas?
Edit: Forgot to say the car hasn't been to Autozone or anywhere to pull a code yet.
Old Feb 24, 2009 | 03:46 PM
Rick99's Avatar
You may be able to pull the codes by turning the key on-off-on-off-on without starting the engine and then read the codes in the odometer. There's not much we can tell you without the codes. If the "louder" sound seems like a hole in the exhaust, that could certainly cause a code to set (either an O2 sensor code or a catalyst efficiency code). If you can't lift the car to look at the exhaust system, you could try looking under the car when you start it on a cold morning and see if there's exhaust smoke coming from the wrong place.
Old Feb 24, 2009 | 03:50 PM
swimjax's Avatar
Thanks! I will take a look.
Old Feb 25, 2009 | 12:24 AM
irdaneel's Avatar
An exhaust leak, especially one in the EGR system, can cause noise and will undoubtedly set off the exhaust back pressure sensor. (Included as part of the EGR valve.)
studentmechanic
Aug 26, 2009 10:05 PM
praasch
Jul 24, 2009 11:01 AM
Minus5252
Jan 19, 2009 10:26 AM
ymitchell
Jun 3, 2008 07:51 PM
Netjunky
Jul 6, 2007 10:25 PM
