Heat and a/c
Old Feb 27, 2009 | 01:55 AM
mwstant's Avatar
Default Heat and a/c
My switch for my heat and a/c only works on 4 and is just off on any other setting can someone tell me what i need to fix this problem?
Old Feb 27, 2009 | 11:42 AM
irdaneel's Avatar
There should be a resistor in the blower area that has probably gone bad. It seems to be a common problem.
Less commonly the control switch itself can go, or part of your wiring harness has come loose.
Old Feb 27, 2009 | 09:10 PM
It's a blown resistor. The fact that it only works on "4" is because the circuit bypasses all resistors on 4. Use the search function on site here and you'll find lots of discussion on the issue including step-by-step replacement instructions. It's an easy do-it-yourself repair. Only caveat is if you are a really big person you may have difficulty bending down under the dash.
notsoperfect187
Nov 13, 2013 06:12 PM
reyesraiders1
Nov 11, 2010 09:39 PM
Bigfan3
Jun 13, 2010 12:35 PM
davet
Dec 19, 2007 04:18 PM
bluepacifica
Apr 27, 2007 04:41 PM
