Changing Headlight Bulbs 2002 Sebring Sedan SLX 4 door
Old Nov 18, 2008 | 02:29 PM
zingerlicious's Avatar
Default Changing Headlight Bulbs 2002 Sebring Sedan SLX 4 door
Well I got my brake lights fixed.... it was the switch, now one of my headlights is gone. It is only the low beams but I know they are a single bulb. At first glance i am thinking I have to remove the engine to get at the rear of the reflector assembly... ok maybe not that bad, but I am hoping I am missing something and it wont take hours to change a bulb. It is the drivers side bulb if that makes any difference.
Thanks for the help.
Old Nov 18, 2008 | 04:16 PM
Default RE: Changing Headlight Bulbs 2002 Sebring Sedan SLX 4 door
If you have the owners manual, it tells you how to change the headlight bulbs. You can get a manual online at chrysler.com. In the meantime, look for two bolts on the upper radiator support behind the headlight. Remove them and you can pull the headlight out. It may help to remove the three push-in fasteners holding the bumper cover near the headlights. Pry up the center of each fastener, then pull the whole thing out. They are pretty easy. Don't disturb the aiming screws.
With the headlight pulled forward get your hand in behind andturn the collar holding the bulb and pull the bulb out of the headlight. Now you can change the bulb. Don't touch the glass of the new bulb with your fingers when re-installing. The oils from your fingers can contaminate the glass, which operates at high temperatures, and can cause it to break, which is bad.
It may be tough to turn that collar while re-installing because they don't give you much room, but it's possible so keep atit.
Have fun.
Old Nov 22, 2008 | 01:56 AM
JimboXL's Avatar
To add to the above post, you are loosening and removing the two silver bolts, leave the others alone. You'll see it. I just changed my headlight in the dark just based on doing a quick internet search with the only response saying to undo the two silver bolts, so it isn't that difficult.
RedLdr1
Jul 10, 2015 11:48 AM
PhilDotC
Mar 5, 2013 01:24 PM
SpudlerT+CTouring
Mar 22, 2012 11:30 PM
zingerlicious
Jul 17, 2011 07:58 PM
SXTNNY
Jan 14, 2009 08:52 AM
