Changing the rear spark plugs on 04 sebring GTC 2.7
Old Oct 26, 2008 | 12:55 PM
Morris04127's Avatar
Default Changing the rear spark plugs on 04 sebring GTC 2.7
I change the fronts fine just need to know if any special tools are needed for the rear
Old Oct 26, 2008 | 12:56 PM
Default RE: Changing the rear spark plugs on 04 sebring GTC 2.7
need help on the rear plugs
Old Oct 26, 2008 | 06:40 PM
irdaneel's Avatar
Didn't find any details in my short search for you, but most of the time a full set of combination wrenches and sockets are all it takes. If you need to remove parts to get to them, some Torx drivers may be necessary, but those are becoming more and more common to most tool boxes.
Be sure to replace any gaskets on parts you have to remove, and replace your wires. (Especially if you need to remove your air intake plenum to get to the plugs, like you do on my 2.5L.)
Old Oct 28, 2008 | 11:25 AM
You need the usual socket for the plugs, plus some short extensions and a u-joint to get the rear plugs out and back in. Since you have done the front plugs, you know what to do to get the coils off. To get the plugs out, put the u-joint in between a couple of short extensions on the socket. Then you will be able to drop the socket down the hole by "rolling" the whole thing in, coming in from behind the engine. If you try to use one extension and the u-joint, you won't be able to get the wrench back out of the hole. (This is the voice of experience here.)
It's pretty easy once you get the technique down. Be sure to put some anti-seize on the threads of the plugs before installing them, and use a piece ofrubber or plastic tubing to hold the plug to start the threads in.
Report back here with your experience so others can have the benefit.
Have fun with it.
Old Jun 27, 2010 | 09:06 PM
Creedman213's Avatar
Any advice as to how to remove the rear coils? there is not enough room to bring them up
Old Jun 28, 2010 | 09:17 AM
They'll come out. Roll them toward the rear. The connector to the plug is flexible enough.
DKenn08
Jan 7, 2013 08:18 PM
queengsc
Apr 17, 2012 03:26 PM
ronypal
Mar 29, 2012 06:20 PM
whodeyrob
Nov 5, 2009 10:19 AM
GT Pony 1
Oct 20, 2009 09:02 PM
