Chrysler 200 head gasket repair a year ago, same symptoms again
Old Feb 19, 2024 | 03:44 PM
shea.m.79's Avatar
Unhappy Chrysler 200 head gasket repair a year ago, same symptoms again
Like the title says, I got my 2016 Chrysler 200 V4 head gasket repaired last March. It was a very long process with the mechanic running me around. I had all of the typical symptoms; cylinder misfire, white exhaust, no external leak, milky oil, very fast coolant draining, etc. Now, I have the same issues again. I took it back to the same shop that I originally went to and they said that coolant is definitely seeping into the engine, but they need $1000 to teardown the engine (6 hours of work with their very high hourly rate) to see if it's the head gasket again or a cracked/warped cylinder head. They'd fix it for free if it's a head gasket but I'm on the line for the fix/replacement if it's a cracked head. This is the only shop near me that does these head gasket replacements at all. This is a Chrysler dealer, although it's not the dealer the car came from.
The car has about 120k miles so it really shouldn't be having these issues, but I bought it used at 105k miles two years ago so who knows how it was treated before that.
My question that actually directly pertains is: is it at all likely that it's actually the head gasket that failed again, or do you think that it's probably a cracked head itself? I have no clue what I'd do if it's a cracked head, but I'd probably have to get rid of the car if that's the case, and I don't want to spend $1000 for them to just tell me that I need to junk the car. I want to make an informed decision about this, and if it's far more likely that it's not a head gasket, then I might as well cut my losses. Any advice about this situation in general would be appreciated.
Old Feb 22, 2024 | 03:09 AM
pandiko's Avatar
Banned
Is there some thing else the Chrysler Chrysler 2 hundred Mechanic have to realize earlier than I join you? Rest confident that they will be able that will help you.
Tutuapp 9Apps
Old Feb 22, 2024 | 12:17 PM
Head gaskets dont fail heads warp did you have the head machined when the head was off? a modern head gasket is 3 layers of steel what do you think the odds of 170psi of compression blowing threw 3 layers of steel?
Old Feb 29, 2024 | 04:15 PM
shea.m.79's Avatar
They should've machined it but who knows with that stupid *** shop. I've decided I'm just getting rid of that car.
Thomcat
Dec 14, 2022 07:04 PM
Driveway Al
Jan 16, 2012 04:55 PM
tintin
Jan 25, 2011 02:01 PM
sheepdog
Nov 17, 2010 03:53 PM
savagedl
Cirrus & Breeze
Jul 18, 2007 09:37 AM
