Chrysler Sebring Cabriolet 2010
Old Aug 16, 2014 | 07:56 PM
DianaS's Avatar
Default Chrysler Sebring Cabriolet 2010
I have had my Sebring since new, now suddenly stuck in 3rd gear - anyone else had this happen and if so how to solve??
Old Aug 22, 2014 | 02:33 PM
ChryslerCares's Avatar
Sounds like you may have a speed sensor issue. The Powertrain Control Module (PCM) uses two speed sensors, one to measure input RPM and one to measure output RPM. These inputs are essential for proper transmission operation. If they fail, it can cause the transmission to go into "limp mode" where it stays in one gear to "protect itself" from further damage.
I'm assuming there is a check engine light or other fault code. Get the codes read from your dealer or other facility to verify what faults are stored.
Good luck on resolving this issue asap!
Chris Danger
Mar 24, 2014 11:32 AM
csa
Oct 23, 2012 08:52 AM
sodakmopar
Aug 24, 2011 09:40 PM
sodakmopar
May 18, 2011 02:40 PM
Chrysler Information
Aug 25, 2009 01:02 PM
