Taller tires on my 2010 Sebring 2.4
Old Feb 23, 2011 | 08:33 AM
sodakmopar's Avatar
Default Taller tires on my 2010 Sebring 2.4
Can I run taller tires on my 2010 Sebring 2.4 without any negative consequences? I want to fill out the wheel well a little better. I've done it will my mopar truck and suv with no ill effects. I was also able to reprogram the PCM so that the speedo was still reading correct. Are you able to reprogram the sebring PCM to reflect a change in tire size? Is it possible to find a site showing what oversized tires will fit and what won't? Will it damage my transmission or anything by running larger than stock tires? Thanks!
Old Feb 27, 2011 | 09:24 PM
sodakmopar's Avatar
mopar
Old Aug 10, 2011 | 12:55 AM
sodakmopar's Avatar
bump!!!!!
Old Aug 10, 2011 | 09:07 AM
I see you have gotten no response in six months on your question. I don't know about your 2010, but on my 2001, there was very little clearance in the wheel wells. The idiot who owned the car before me tried to use SAE tools on metric bolts, and wound up leaving a 1/2 inch socket stuck to the head of a 13mm bolt that held the battery in place. That socket lifted the battery cover a little toward the tire when he put it back together, and as a result, the tire wore a hole through the battery cover.
I would suspect that there probably isn't a great deal of difference in the case of the 2010.
Old Aug 10, 2011 | 05:49 PM
sodakmopar's Avatar
thanks for the reply. I will just have to put one tire on a ramp for articulation and do some measuring.
Old Aug 20, 2011 | 11:31 PM
helo735's Avatar
why not just lower it?
Old Aug 21, 2011 | 10:19 AM
sodakmopar's Avatar
Then I will have clearance issues and a broken front bumper.
Old Aug 24, 2011 | 09:40 PM
Bib's Avatar
Bib
go to miata.com, there should be no problems.
kzee
Sep 18, 2014 09:24 PM
cowoygunner14
Feb 27, 2014 11:30 AM
adam.davis
Dec 30, 2010 06:48 PM
redleopardette
Feb 14, 2006 04:42 PM
redleopardette
Feb 10, 2006 06:46 PM
