clip on hydraulic tensioner for timing chain
Old Jan 8, 2015 | 07:34 PM
jimG's Avatar
Default clip on hydraulic tensioner for timing chain
I am replacing the water pump on my Sebring 2.7L. When I removed the hydraulic tensioner for the timing chain I noticed that the small wire clip at the top of the tensioner was not on, it was laying in the cover for the tensioned. When I tried to put it back on it easily broke in half.
I don't really see a purpose for this clip.
My question is: Is it needed?
I don't want to replace the tensioner if it is not needed.
Thanks for any advice
Jim
Old Jan 9, 2015 | 10:26 PM
Might be there to hold the tensioner back during assembly. If that's the case, it would not have any use once the tensioner is pressurized. Guessing here.
Old Jan 10, 2015 | 08:49 AM
jimG's Avatar
Thanks for the input,
I was thinking the same that is was just for assembly. It may hold the tensioner in place after the block is assembled but before the heads and timing chain are installed, My best guess also.
Just wanted another opinion, and we seem to have come to the same conclusion. I think I will run with what I have.
I really like the 2.7, but I do not think much of its cooling system. That is the downfall of this engine, but with that said I know what I got and understand the weak points. Getting ready to roll over 200,000, without any trace of the reported sludge problem
Jim
Old Aug 24, 2016 | 10:24 PM
kevinfish's Avatar
Default missing/broken tensioner clip
Jim
I know this is a very old thread but since I just had the same problem, after pulling it apart I found the previous mechanic just left along with the tensioner o-ring completely out, it dawned on me the clip is there to limit the amount of extension the tensioner can exert against the guide to a reasonable amount. Without it, the tension would just keep in working its way down its bore until it might even fall into the block! (Not likely but perhaps it's possible. Either way the chain and/or guides should be changed long before such a thing might happen and this is built such that you should be forewarned by a little chain slap before such an event by the clip holding the tensioner back).
I just went to my hardware store and bought a $.70 "C" clip which I'm sure will do the trick
jimG
Aug 24, 2016 10:34 PM
lovenhate300m
12
Mar 29, 2012 11:50 PM
bacalao
May 9, 2008 11:34 AM
bacalao
May 4, 2008 07:46 PM
bacalao
May 4, 2008 04:15 PM
