Common oil leaks?
Old Jan 23, 2007 | 01:03 PM
svoboda's Avatar
Default Common oil leaks?
After spending close to a grand to get new wheels, tires and to replace the water outlet housing and thermo, I am now smelling oil. Anyone had problems with an oil leak? What are some common areas to check?
Old Feb 15, 2007 | 04:35 PM
drivewaytech's Avatar
Default RE: Common oil leaks?
If you smell oil burning, this usually means the leak is originating from the top end of the engine. The smell of burning oil generally come from oil dripping on the exuast manifolds. Look to see if you have stains around the valve covers and make a habit of checking your oil level weekly. Engines need to have full bellies of oil.
Old Mar 6, 2007 | 01:32 AM
ace's Avatar
ace
You may want to check trans cooler lines and clamps dcx has some crappy clamps on their hoses.
Old Aug 9, 2009 | 11:33 AM
momylvinc's Avatar
We took our 98 Sebring Conv. to a mechanic because we smelled oil burning, they changd the PCV Valve but we still smell it burning, they said there are no leaks. We dont see anything in the driveway or the garage that is driping on the ground. Any clues?
Tris1
Jun 1, 2017 07:26 PM
eldnpat@gmail.com
Aug 23, 2015 07:14 PM
sassy
Jan 7, 2011 06:06 PM
Chrysler300MSpecial
Dec 6, 2009 07:51 PM
fibersport
Aug 1, 2007 09:19 PM
