coolant issue...
Old Jun 23, 2005 | 09:56 PM
JXI101's Avatar
Default coolant issue...
So, when we bought the car 8 years ago.. something was arong with it and like the coolant they used did something and it like corroded the coolant lines on the engine block or something... now even with my bi-annual radiator flush, my coolant always looks rusty or kinda rust colored.. not a good thing I'm guessing... Anyone know anything about this?
Old Jun 30, 2005 | 03:04 AM
Emersive Audio Video's Avatar
Default RE: coolant issue...
You know I had the same thing with my very first car. I had an 82 Pontiac Grand Prix.
Ok I had it for 4 days before I wreckd it, but lets no go there ok...
The coolent was ALWAYS BROWN. I flushed it problably 2 X and put all new coolent in it and yet its still turned rust brown. I dont know whats up with that and we never could figure it out. Granted I had the car for 4 days so maby it would have eventually cleared up. I doubt it though. I wanted to post this so you dont think your the only one with or had that problem. However in my sebring the coolent is GREEN.
Old Jul 11, 2005 | 09:27 PM
2004LX's Avatar
Do the newer Sebrings use DexCool?
Old Jul 11, 2005 | 09:35 PM
BadStratRT's Avatar
Administrator
technically, NO DCX products use DexCool...GM owns the rights to it....the new sebrings use ehtylene glycol, but it newer DCX products do have some that use non-green coolant...just have a look in your rad some time...*when the engine is cool*...it is probably green..mine is, but im not certain of yours
Old Jul 12, 2005 | 12:04 AM
redcali's Avatar
brown **** in the fluid is from oxidization within the pipes, its not bad and all the residue should build up in your overflow tank/area. mine is a real nasty brown but still sits below 90 all the time... never had a problem with over heating at all.
how do you flush the tank? with water? because that could be part of the problem.
Old Jul 12, 2005 | 12:08 PM
BadStratRT's Avatar
Administrator
if you go to a place that offers power flush and fill, that may help a bit...make sure it is FLUSH AND FILL...not drain and fill...you can do that at home. they should hook up a machine that sits about waist high..with severeal hoses and power lines..ive seen people pay for what they were told was a power flush, and it was only a drain, which leaves alot of the low laying dirt in the block.
Old Jul 13, 2005 | 09:56 AM
2004LX's Avatar
ORIGINAL: BadStratRT
Ahhh, ok. I know of GM cars that use DexCool, interesting about the rights to it. I just know that when I looked under the hood the first time I could tell from the coolant reservoir that it was not green. I was concerned about DexCool because I heard some people saying that it eats away at gaskets and/or plastic. Whether that is true or not I'm not sure...I've also heard people saying good things about DexCool.
Evertb
Sep 19, 2012 02:46 PM
RAYCUDA
Jul 10, 2011 11:07 AM
neoncrazy101
Sep 7, 2009 06:05 PM
tehkoch
Sep 17, 2008 11:23 AM
PSD Trav
Apr 20, 2007 01:47 PM
