coolant leak metal pipe bottom center rear of engine
Old Jan 12, 2012 | 07:40 PM
besterfe's Avatar
Default coolant leak metal pipe bottom center rear of engine
I have a coolant leak metal pipe bottom center rear of engine. seems to be a hole in top of this pipe. any suggestions.
Old Jan 12, 2012 | 07:43 PM
besterfe's Avatar
Default 1999 sebring convertible
should have said what car this is on
Old Jan 12, 2012 | 09:38 PM
replace it might as well do the timing belt and water pump because all of that has to come off to replace it
Old Jan 16, 2012 | 07:36 PM
besterfe's Avatar
I have talked to the chrysler dealer and they say this part is discontinued. I have not been able to put the car up on ramps to really be able to look at it, but from what i can see it bolts in on the left and right of the engine, i do not understand the need to remove water pump, which requires timing belt...
Old Jan 16, 2012 | 10:53 PM
buy a service manual and read on how to replace that pipe then u will see why u need to remove the water pump
So this part number has been discontinued? MD198102
KonfusedGuy
Jun 23, 2015 08:35 AM
Shadowed
Feb 27, 2013 02:40 PM
boehmex5
Sep 19, 2012 02:49 PM
neh218
64
Nov 28, 2011 03:54 PM
Spellbreaker
Mar 11, 2010 04:27 PM
