Coolant leaks 3.5 Sebring
Old Aug 2, 2020 | 11:21 PM
kaheu's Avatar
Default Coolant leaks 3.5 Sebring
New here, tried searching the forums, couldn't find exactly what I'm looking for. My 08 Sebring with 3.5 v6 is leaking coolant, badly. Cant find the leak. Water/coolant is gushing from what appears to be the rear of the passenger side. I cannot find a diagram or outline of where all the coolant hoses are running, the hoses from the tank to radiator are fine, into thermostat are fine. It seems like it could be the water pump housing but from what I can see its not leaking, but I cannot see the hose on the other end. Has anyone encountered a coolant leak coming from the rear passenger side of the engine? Or does someone have the coolant hose diagram so I can better track down this issue.
Old Aug 3, 2020 | 11:01 AM
https://haynes.com/en-us/chrysler/sebring/2007-2010
It'll be worth the money even if you decide that the repair is beyond your capabilities. You'll be able to deal with the shop more intelligently with the knowledge you get from the book.
Old Aug 3, 2020 | 11:24 AM
kaheu's Avatar
online version the same as the hard book? Just curious if one is better than the other.
Old Aug 3, 2020 | 04:00 PM
If you buy the book, you get to keep it, and can take it out to the garage while working on your car. The online deal is a time-limited subscription, if I understand it correctly. I suspect the information is pretty much the same.
AdamLag
Nov 3, 2017 10:59 PM
PMBennett
Jan 18, 2017 09:14 AM
QLHS
Oct 6, 2013 06:23 AM
teddysmith1952
Dec 16, 2011 08:31 PM
Don's '99 300m
Apr 27, 2011 08:34 AM
