Damper fork touble
Old Nov 10, 2011 | 05:46 PM
fakeplay's Avatar
Default Damper fork touble
Hi I'm changing over my stuts and the damper fork is giving me trouble.
The bolt to the lower control arm will not budge. I backed off the nut to the end of the bolt and wacked it with a hammer but it did not move. Any suggestions ? ps I did not remove the stablizer but does that matter ? the bolt should have moved should'nt it ? Thanks
Old Nov 11, 2011 | 01:26 PM
What kind of car are we talking about here? I assume it's a Sebring, but what year and model? Coupe? Sedan/convertible?
Old Nov 12, 2011 | 09:59 AM
fakeplay's Avatar
Default damper fork
Hi, It's a 98 sebring conv. jx The bottom bolt to the damper for (clevis bracket) The bolt seem to be frozen in. I hit it pretty hard a couple of time but it did not budge. Would heat work you think ? Thanks
Old Nov 13, 2011 | 05:18 PM
Be careful with the heat. There's a bushing there you don't want to ruin if you can help it. I believe that bolt has a serrated shoulder to prevent it from turning. Those serrations have a lot of surface area that has probably gotten corroded over the past 13 years. You might want to try some PB Blaster and ATF in there, then get a bigger hammer. You'll probably need to replace the bolt after all that beating on it.
Old Nov 14, 2011 | 09:11 AM
fakeplay's Avatar
Default Damper fork
I know there's no bushing. I have two spare clevis bracket s And they are just flanged bolts. Yup, maybe a bigger hammer (wich I have) Thanks
kgillespie
Jul 27, 2021 08:34 AM
sharkygb3
Apr 3, 2014 01:57 PM
harrysaimbhi
23
May 6, 2010 02:42 AM
harrysaimbhi
Mar 29, 2010 06:52 AM
jakefree
Jan 27, 2007 07:36 AM
