dash cluster
Old Nov 21, 2005 | 04:27 PM
  #21
JXI101's Avatar
Default RE: dash cluster
If you can fix yours, then go for it, but they are interchangeable... It's the same gauge package, but they are right about having to have the same transmission setup
Old Nov 21, 2005 | 06:29 PM
  #22
sulup's Avatar
I found a technical breakdown on how to fix the cluster on yahoo.It`s great,it shows step by step on how to remove the dash cover,take cluster apart,which resistors to solder,and putting it back together.I went ahead and followed the steps,now all I have to do is install it and hope it works. Thanks for all your help and support.
Old Nov 23, 2005 | 10:44 AM
  #23
sulup's Avatar
This is for dusterdan and jxi101, Just to let you guys know I fixed my dash cluster.Thanks to both of you for opening different ideas for me to try. Now I have other issues with the car(97 sebring conv.)#1-When turning the wheel either left or right not moving,I hear a slight thump noise in the front end,only when turning the wheel.I had a couple of so called mechanics look at it ,they told me that either the lower control arm bushings were bad,or the front and rear motor mounts were bad.Well I replaced them,the front & rear motor mounts & the lower control arm bushings(just one on each side) and guess what,That`s right the noise is still there.Any clue is to what it could be before I empty my bank account?#2-I have the stock radio(am/fmcass)The volume is up all the way,I cannot lower the volume,I turn the **** but it keeps turning like It`s stripped. Any info On that issue? Thx
crysler
Apr 30, 2013 08:13 PM
deef
Nov 6, 2008 10:44 AM
94_LHS
Aug 1, 2006 02:24 AM
proc
Mar 14, 2006 12:02 AM
sulup
Nov 23, 2005 10:48 AM
