Dash warning lights and radio click on and off
Old Nov 28, 2009 | 02:54 PM
mjmangus's Avatar
Default Dash warning lights and radio click on and off
2006 Sebring. While driving, the ABS and traction control lights come on, the odometer goes blank, and the radio cycles or clicks. It's kinda like when you first turn the key on and everything cycles on then off when starting. Seems to happen when hitting a bump in the road. I suspect a loose connection. Any suggestions as to what may cause this or where this connection might be located? Thanks for your help.
Old Nov 29, 2009 | 03:14 PM
It does sound like a loose connection, I would guess a ground. You didn't say whether it's a coupe or sedan (they are very different) but I would start with the battery and check every ground strap I can find.
Old Nov 29, 2009 | 07:41 PM
mjmangus's Avatar
Sorry, it's a sedan. I will start with the grounds, but is there a particular connector that commonly causes problems like this?
Old Dec 2, 2009 | 09:46 PM
mjmangus's Avatar
Apparently a chime (bell) sounds every time this happens. Is there something common with the chime and the lights that I can look at? This is my daughter's car so sorry about the haphazard info. She's bringing it by tomorrow so I would like to have ducks in a row when I start checking it out.
Old Dec 3, 2009 | 05:06 AM
car123's Avatar
Old Dec 7, 2009 | 03:08 PM
mjmangus's Avatar
Well I got the car and started checking things out. When the problem occurs you hear a chime and the Brake and Traction Control lights come on. I checked the brake fluid level and it was really low. I topped off the reservoir and the lights/chime thing stopped and no matter what I do I can't get the problem to repeat. I'm tempted to syphon off some of the brake fluid to see if I can get it to repeat. Could the low level be the cause of the problem?
Old Dec 7, 2009 | 07:53 PM
Rather than wonder why the problem is fixed, it might be better to explore why the level is so low. Is there a leak? Are the pads worn so much that they need replacement? Might be time to replace the fluid as well.
The brake fluid level switch operates through a microprocessor in the instrument cluster, and the low fluid may explain the symptoms you saw.
Old Dec 8, 2009 | 10:17 AM
mjmangus's Avatar
That's what I did. When topping off the fluid cleared the alarms, I pulled the wheels off and found the brake pads were worn out. There was no evidence of leakage. I then lowered the level to where it was and after the new pads were installed the level wound up just slightly below the full mark. Will consider fluid changeout when I get more time. Thanks to all for their input.
TheAverageDan
Jun 2, 2015 06:31 PM
cuda2000
16
Jan 14, 2014 03:42 AM
BrianF
Nov 12, 2013 04:19 PM
mr_twe
13
May 23, 2013 11:20 PM
ecarter
Sep 14, 2012 11:15 AM
