Driver window wont go down at times...'01 Limited
Old Jul 1, 2011 | 01:47 AM
Ribguy's Avatar
Default Driver window wont go down at times...'01 Limited
The window goes up with no issues when it is down. There are times that I have to use the button/switch several times for the window to go down. Bad switch? Relay?...I'm thinking switch. As always, thank you in advance for your time and answers.
HAVE A SAFE AND HAPPY INDEPENDENCE DAY WEEKEND ! ! ! !
Old Jul 1, 2011 | 01:54 AM
Ribguy's Avatar
Does the door panel have to come off to get to the master switch? It looks like it sits in it's own panel with the door close handle, or maybe that is the way the plastic is molded on the door panel to look like a separate piece.
Old Jul 1, 2011 | 08:11 PM
Yes, you need to remove the door inner panel.
Remove screws holding arm rest area, screws at bottom of door, speaker covers and speakers, clips at back edge and when you've gotten all the screws and clips undone, lift the panel up off the door at the top, don't pull it out at the top.
ericsptcruiser
Aug 6, 2012 12:15 PM
jaustinp
Feb 7, 2012 08:35 AM
Vincenthrd
Jul 29, 2009 02:19 PM
funjon1
Jul 12, 2009 06:04 PM
davet
Aug 11, 2007 04:17 PM
