Electric Fan Relay location
Old Jun 17, 2013 | 12:37 PM
xzsbkn's Avatar
Default Electric Fan Relay location
I have a 2004 Sebring Convertible and the electric fan is not coming on. It does not work when the vehicle gets hot (temp gauge all the way to red last time) or when I turn on the AC. It has a two fan unit (I assume one for the AC and one for the cooling). The AC also does not work, but I'll save that issue for later.
I would like to check the relay to see if it is bad, but I don't know where it is located. I looked at the diagram for the under the hood fuse/relay block in the owner's manual, but it did not identify anything for the Electric fan. Does anyone know where that relay is located? Pictures are always appreciated
Old Jun 17, 2013 | 02:43 PM
The fan relays are in the power distribution center, which is a fancy name for the fusebox under the hood. There is a row of large relays across the rear of the box. The fan relays are the two outboard ones. One is for low fan speed operation, the other for high fan speed operation.
Turning on the A/C won't make any difference if the A/C is not working, but they should come on before the temp gauge gets all the way to the red regardless.
Old Jun 18, 2013 | 08:19 AM
xzsbkn's Avatar
I'm not following you on the 'outboard ones'. Here's my PDC. Which are the two 'Outboard Ones'?
Old Jun 18, 2013 | 08:26 AM
xzsbkn's Avatar
Old Jun 18, 2013 | 11:07 AM
The ones closest to the edge of the car. The ones in the top row most to the right in the picture.
dwtcst
Jan 16, 2011 07:16 PM
northwind
Jan 14, 2011 02:07 PM
rojo
Mar 22, 2009 09:25 AM
dphickster
Feb 3, 2009 01:38 AM
defektivrobot
Apr 22, 2008 12:47 PM
