Engine cranks but take time to start when cold
Old Apr 19, 2010 | 02:12 PM
darlon's Avatar
Default Engine cranks but take time to start when cold
Our 2002 Sebring 2.4L 4cyl DOHC will will crank over just fine however it will take about 5 seconds to start first thing in the morning (temp outside is 75F). After it has been running and is shut off-- if you start it up again fairly soon it will start up right away. Very frustrating.
The battery is good (12.7 volts and passed a load test), spark plugs are new and have spark. Alternator charges the battery at approx 14.3-14.4 volts when running. All fuses are good.
I put a fuel pressure test gauge on the schrader valve on the fuel rail to check the fuel pressure. When the ignition is turned on, not started, the fuel pump will run for 1-2 seconds and shut off (normal it think). The fuel pressure during this check is 58psi while the pump runs and then drops to zero. (I'm not sure if it is suppose to drop to zero or not). When the engine is running the pressure reads approx 58psi and seems to operate normally.
I'm thinking it's the fuel pump that is causing it to be hard to start in the morning or if it's been sitting for an hour or so. Almost like the fuel rail is not staying pressurized or pump isn't supplying enough fuel pressure until the crankshaft sensor senses the crankshaft turning.
Any help is greatly appreciated
thanks
Old Apr 19, 2010 | 02:58 PM
There's supposed to be a check valve in the fuel pump to maintain pressure in the lines. Sounds like yours is not functioning. I assume yours is a sedan. The bad news is that you can only get access to the fuel pump by removing the fuel tank.
Old Apr 19, 2010 | 06:17 PM
Moparkyle's Avatar
Dragging starter possibly?
Old Apr 19, 2010 | 06:19 PM
Moparkyle's Avatar
If you think it has to be something with the fuel delivery, try to prime the pump a 3 or 4 times before starting, this is done by turn key to the on position and off a few times.
crmzendrgone
Cirrus & Breeze
15
Nov 15, 2011 10:18 PM
chengthao85
Jun 11, 2011 03:08 PM
size2020
Oct 17, 2009 08:21 PM
Greg
Jul 30, 2009 09:34 AM
jonboy_4x
Apr 6, 2008 12:19 AM
