Engine runs 10-30 mins then quits HELP!!:(
Old Jun 11, 2008 | 05:21 PM
Sebring Star's Avatar
Default Engine runs 10-30 mins then quits HELP!!:(
Hi all,
I'm in desperate need of help here. Engine quit, wouldn't start, no fuel pressure,replaced pump.
Two weeks later again, distributor code from PCM, replaced with new distributor & crankshaft sensor. Engine now will run for about 10-30 mins but then quits, turns over but no spark.
If left to cool down for 2 hours or so will start & run again, also bluish black smoke coming from exhaust a little at first then increases. PLease Help I'm totally stumped on this one, also no trouble codes are showing. All help is greatly appreciated.
Old Jun 16, 2008 | 09:25 AM
irdaneel's Avatar
Default RE: Engine runs 10-30 mins then quits HELP!!:(
Bluish black smoke usually indicates that you are burning oil, and increasing temp and smoke together tends to confirm it. That is usually valve guides or rings, a relatively expensive repair.
As far as your no start / no run / no spark problem, look for an "Automatic ShutDown" relay. They can be problematic and not throw codes.
Old Jun 17, 2008 | 10:02 PM
bandaide's Avatar
You might also have an issue with the crankshaft position sensor. This works with the Camshaft sensor to provide correct fuel and ignition timing.
Lanvale
Oct 12, 2011 05:21 PM
KissMyBass
Nov 3, 2008 04:11 PM
cajunsprt
9
Jan 25, 2008 01:06 PM
mc
May 13, 2007 11:11 AM
DJ_Playing
Apr 22, 2006 03:58 PM
