Engine stalls at red lights
Old Sep 30, 2013 | 11:48 AM
gromit95's Avatar
Default Engine stalls at red lights
I have a 2008 sebring 4 cyl auto with 150+ miles on it. I got it used and it worked for a year without issues. Then it started to stall at red lights or when driving in a parking lot. I did get an engine code but it was for an evap leak (fixed) I replaced the plugs ,wires and coil. Problem solved for 2 weeks car was fine then started doing same thing. Replaced the coil and it was better. Now 2 weeks later its back. An I just getting bad coils or is something causing them to burn up???
Is there something else I should be looking at?
Thanks fred
Old Sep 30, 2013 | 01:51 PM
Throttle body gummed up?
EGR valve need to be replaced?
Idle air control motor bad?
Old Oct 1, 2013 | 08:20 AM
gromit95's Avatar
throttle body gummed up-cleaned it when i did the pluges and wires and coil
egr will give it a try
what is it ??where is it?? Idle air control motor bad?
thanks fred
Old Oct 1, 2013 | 08:36 AM
gromit95's Avatar
would a bad egr or idle motor give an engine code???
fred
Old Oct 1, 2013 | 03:39 PM
gromit95's Avatar
update
according to dealer 2004 sebring 4 cyl has no egr valve
Old Oct 14, 2013 | 02:25 PM
gromit95's Avatar
Default i'm driving it now
in order to dianose the issue i started driving the car myself.
it starts with no issue and drives fine. when you get to a stop light the idle will stuble once maybe twice before its green again.
i noticed a loud knok in the front - tie rods are shot - need to fix that asap befor idle issue
if you had to chose -whitch is more likly bad egr or idle motor???
thanks fred
debbieking
Nov 20, 2018 08:15 PM
jeepdaddy65
Jul 1, 2013 09:48 PM
GO PATS
Dec 11, 2012 08:53 PM
CWH
May 2, 2008 05:35 PM
Racinfan83
Dec 10, 2005 11:50 PM
