front end shimmying left to right
Old Mar 25, 2010 | 07:27 AM
billyd10's Avatar
Default front end shimmying left to right
When i am driving 55to 60 mph the car shimmys from lrft to right even when i hit little bumps in the road
billyd10's Avatar
whatever
Old Mar 25, 2010 | 09:43 AM
"Shimmy" usually refers to a vibration in the steering wheel. If the car lunges to the left that's something different.
Vibrations in the wheel are often caused by tires out of balance or out of round. If they occur during braking, they are often caused by warped rotors.
Vibrations can also be caused by worn driveaxles or worn ball joints.
Lunging or "pull" to one side can also be a symptom of worn ball joints.
If you have a set of jackstands, put the front end up solidly on the stands and give the front end a careful inspection. Look for wear patterns on the tires, loose ball joints, or other problems with the front end.
If you're not sure what to look for or are not comfortable with this, take it to a competent shop and have it inspected.
Old Mar 26, 2010 | 08:44 AM
bjkroll's Avatar
I've had a bad wheel bearing cause a bit of a "shim". You would know if the bearing was bad though by a constant hum (or even worse, a grind!)
Old Apr 3, 2010 | 02:54 AM
jennifermilly's Avatar
Smile front end shimmying left to right
swittie
Nov 10, 2020 02:02 PM
brownmal
Jan 9, 2011 05:28 PM
billyd10
Mar 31, 2010 10:07 AM
Mnivens
Dec 23, 2008 09:47 AM
BMW4631
Apr 17, 2008 11:01 PM
