Heated seat does not work... ??? !!!
Old Nov 26, 2007 | 06:53 AM
flaxi's Avatar
Default Heated seat does not work... ??? !!!
My heateddrivers seat does not work - have checked wiring under seat and appears okay - any ideas? [:@]
Thanks a lot !
(how to change the pad ????)
Felix
Old Nov 26, 2007 | 08:29 AM
moe's Avatar
moe
Default RE: Heated seat does not work... ??? !!!
what year is your car? heated seat comes out by way of pulling the seat material off the seat and cutting the old wiring out.might just be a relay.does pass.side work?moe
Old Nov 26, 2007 | 09:00 AM
flaxi's Avatar
hi moe, its a 2001 LX 2.7 !
There are different cables under the seat. How can I make a test ?
Passenger side is ok !
Old Nov 26, 2007 | 03:16 PM
moe's Avatar
moe
DRIVER HEATED SEAT CUSHION (CUSHION SIDE)
CAV
CIRCUIT
FUNCTION
A
BL
SEAT HEATER B(+) DRIVER
B
GN
HEATED SEAT DRIVER
C
BK/RD
SEAT TEMPERATURE SENSOR INPUT
D
BK/RD
SEAT TEMPERATURE 5V SUPPLY
cavity "A"should have battery voltage when switch is turned on.wire is blue.look under your seat for this connector,back probe after turning onswitch.if you have 12v.thru your test light.then you narrowed it to the seat.moe
Old Nov 26, 2007 | 04:56 PM
flaxi's Avatar
that helps. Thank you very much, Moe. I'll try it at weekend.
Best regards
felix
Old Dec 1, 2007 | 03:18 PM
flaxi's Avatar
now I found the issue:
I had to strip the leather cover. Under the front part one canfind somewires: 2 black wires and two very fine blue wires, which go to the heat sensor. When I bypassed the two black cables, the heating worked well. So I suppose that the heat sensor was damaged. So, I dont need the heat sensor. I switch to 2, 3 or 4, thats hot enough.
Seriously?
Oct 13, 2009 10:22 PM
niccol
Jan 6, 2009 12:47 PM
gillcoates
Jan 2, 2009 06:49 PM
wifes 300m
Feb 11, 2007 01:59 PM
jesuslike
Jun 16, 2006 02:08 PM
