Insturment Cluster Lights: "Check Engine" light does not work
Old Sep 6, 2019 | 01:57 PM
Michael R. Barnard's Avatar
Default Insturment Cluster Lights: "Check Engine" light does not work
My 2006 Chrysler Sebring convertible Limited, 85,000 miles, 2.7 V8 gas, could not be smogged because the CHECK ENGINE LIGHT is not working. When the ignition is turned on and all lights are briefly displayed, the CEL is the only one that does not display.
It must have worked a couple years ago, when I last had the car smogged.
How do I repair or replace the CEL?
Old Sep 9, 2019 | 03:01 PM
REBEL59's Avatar
It may have just burnt out the bulb in that spot. Not sure of the steps involved on your car to remove the instrument cluster to get to the back and check the bulb. From what I gather from your post, the car drives fine, an electrical problem in the harness or computer would be giving you some type of drivability symptoms. Good Luck
William Umphlett
Jan 2, 2019 09:03 AM
scirocco16v
May 26, 2015 10:05 AM
13walkec
Jan 13, 2014 04:31 PM
KYBarrister
Mar 23, 2009 07:08 PM
deef
Nov 6, 2008 10:44 AM
