Key fob not detected
Old Aug 7, 2024 | 02:28 AM
Beemarie365's Avatar
Default Key fob not detected
My 2015 Chrysler 200 wasn't starting right away. I changed the battery and it started right up. About a week later it wouldn't start at all. It locks and unlocks the car and pops the trunk but will not start the car. I've tried pressing the start button with the key fob, doesn't work. I've tried every trick I've come across the last couple months. Literally nothing has worked. I've changed the battery in the fob about three times and no luck. Tried to 'reset' it, nothing. Even threw the car battery on the charger. Still nothing. So I've got two questions because I could not come across any info on either question. One, could the fob itself be bad when though it locks and unlocks the car? And two, is there a way to manually start the car? Obviously there's a key to open the door so I wonder if there's an actual ignition behind the start button? Thanks!
Old Aug 7, 2024 | 07:56 AM
ggoose's Avatar
Yes, there is a key slot behind the start button. You should be able to pop off the cap to reveal the slot.
Do you have a second keyfob that you could try?
Suggest visiting '200forums.com'. There are a number of very knowledgeable contributors that should be able to assist.
Old Aug 7, 2024 | 10:13 AM
Unfortunately I only have one key fob at the moment. I figured there was a key slot behind the start button but I've found very little information on it on most forums, Google, YouTube, etc. But I will definitely check that forum out. Thank you!
Inkfreek73
Dec 13, 2023 04:20 AM
Some.guy
Dec 25, 2019 09:44 PM
Edward Josph Arellano
Dec 28, 2017 06:56 PM
S6Voyager
Jan 14, 2017 09:07 AM
VaSteve
Oct 4, 2008 02:14 PM
