leak and mildew smell
Old Jan 5, 2011 | 02:26 PM
Mariank's Avatar
Question leak and mildew smell
Is there a way to tighten the convertible ragtop to eliminate leaks and a mildew smell?
Old Jan 5, 2011 | 03:29 PM
First you need to determine where it is leaking, if it is in fact leaking. The smell may be coming from the A/C system, which has nothing to do with the convertible top.
If the top is leaking, you need to figure out where it is coming in and fix that leak. It's not just a question of "tightening" something.
There are channels built into the system to allow water to drain out. If one of those is plugged, the water may not be able to drain properly and it may be getting in where it doesn't belong.
Have you noticed wetness inside the car? If so where?
Old Jan 6, 2011 | 02:44 AM
aifam55's Avatar
A common thing that gets clogged up are the drain slots in front of the wheel wells on the bottom. Use a screwdriver to make sure these are clear. If they get clogged you will get water inside. It's good to check them if you never checked them before.
Old Jan 6, 2011 | 01:32 PM
Mariank's Avatar
thanks much for your time
10Miler
Jan 21, 2014 09:14 AM
tsgrayson
Dec 28, 2012 01:19 PM
cslaney
Feb 21, 2011 02:10 PM
PF Mom
Nov 2, 2009 08:30 AM
nauman
Jul 26, 2008 03:42 PM
