leaking trans 2.7l
Old Feb 9, 2008 | 07:02 PM
tbrown01's Avatar
Default leaking trans 2.7l
i have notice transmission fluids in driveway. is the problem with this model leaking only has 61k
Old Feb 10, 2008 | 10:19 PM
master tech's Avatar
Default RE: leaking trans 2.7l
Can you tell if its coming from the front area or the solenoid pack?
Old Nov 12, 2008 | 05:15 PM
billbon8's Avatar
Hello,
I had the same issue with my 01 Concorde (60K miles). I thought it was a tranny leak, but it turned out that two of the pan bolts (front corner driver's side) were slightly loose and the pan gasket had failed. So, I bought a filter/gasket kit from NAPA and changed out the fluid, filter and gasket. I was surprised at the specified bolt torque (19 ft-lbs). However, when removing, the existing bolts were very tight.Refill was about 5.75 qts.
Bill
Old Nov 12, 2008 | 11:59 PM
dodgetech1's Avatar
check the cooler lines
Old Nov 13, 2008 | 09:00 AM
"I thought it was a tranny leak, but it turned out that two of the pan bolts (front corner driver's side) were slightly loose and the pan gasket had failed.I was surprised at the specified bolt torque (19 ft-lbs). However, when removing, the existing bolts were very tight."
Hmmmm. Could it be that somebody previously overtightened the pan bolts, stretching a couple of them (causing them to be "slightly loose" and crushing the gasket under the others?
There's a reason for specifying a certain tightness.
parlayjay
Apr 18, 2010 03:28 AM
Brokenass
Jul 17, 2009 05:17 PM
3.3lxbluevan
May 16, 2008 06:30 PM
jynxx15
Oct 26, 2006 10:46 PM
tmp03tnc
Mar 29, 2006 04:19 PM
