Misfire
Old Feb 28, 2021 | 05:42 PM
Tcove2's Avatar
Default Misfire
Alright so I have a 2008 3.5L Sebring and I have error code p0302 so cylinder 2 misfire. My mechanic and I have tried every test we can think of but we can’t figure out why it is missing. Compression is fine changed the spark plugs and when we move coils the misfire still stays in cylinder 2. Any help would be greatly appreciated!
Old Feb 28, 2021 | 05:46 PM
Tcove2's Avatar
Default Addition
Also it has been missing since I had the transmission rebuilt.
Old Feb 28, 2021 | 06:47 PM
Bad fuel injector or wiring? Might try a can of fuel injector cleaner as a cheap first attempt. Always try the cheapest thing first.
Old Feb 28, 2021 | 06:57 PM
Tcove2's Avatar
I’ve already tried seafoam and my mechanic cleaned the fuel injector but still thinks that it might still be what is causing it.
Old Mar 1, 2021 | 08:47 AM
Could be a problem with the wiring leading to the injector. When you post a problem, it helps if you include in the post everything you have tried to fix it so as not to have people waste your time and theirs suggesting fixes that have already been attempted.
Old Mar 1, 2021 | 08:39 PM
ggoose's Avatar
How many miles on the car? If over 100K, was the timing belt changed? Part of 'package' for a timing belt replace includes a tensioner. If the tensioner is original, it is possible it is not working properly and causing the misfire.
Old Mar 2, 2021 | 04:24 PM
Joseph Brando's Avatar
I had a similar issue with a different car, Chrysler 300 3.6L.....I went through every test possible
see details here:
https://www.chryslerforum.com/forum/...misfire-32419/
Long story short,
They replaced worn-out rockers on cylinder 5 and lifters after which no misfire no DTC
Note: there was no rocker ticking sound whatsoever !!!
hope that helps
Dadgummit
Dec 21, 2020 05:38 PM
Traviair
Dec 10, 2020 01:00 PM
08v627nightmare
Aug 26, 2020 10:02 PM
cjhstang
Sep 18, 2009 10:52 AM
mikecahall
Cirrus & Breeze
Feb 25, 2007 03:47 PM
