Misfire with new OE Plugs
Old Aug 26, 2020 | 10:02 PM
08v627nightmare's Avatar
Angry Misfire with new OE Plugs
My wife bought over priced 08 Sebring 2.7 V6 Convertible. Took to mechanic and he just replaced parts the error codes call for. After getting the car back I still ran into problems. Main thing was a misfire cylinder 2. Since I had some time, I swapped out plugs, coil packs, and fuel injector, and I did not move the misfire. Took it back to get compression check and was told that compression was a little low, but I didn’t think to check the readings myself.
Finally, a previous problem showed up, the car overheated, and I finally put in coolant instead of water. After adding the coolant, I decided to check spark plug and found it with a light dry matte black on it. I checked cylinder 6 and concluded that the cylinder 2 plug was because of overheating. I swapped them and had no misfire at all.
So I safely assumed the coolant was a factor and decided that I wanted OE plugs in the car. I installed new OE plugs and what came back, the misfire. So I analyzed the plugs and the NGK was a shorter gap than the OE CHAMPION plugs. I put the NGK back in and no misfire.
why is the gap difference effecting just one cylinder?
mrls430
Aug 27, 2020 11:44 AM
ThePacLady
Mar 30, 2013 02:12 PM
sebgep
May 6, 2011 06:22 AM
cjhstang
Sep 18, 2009 10:52 AM
mikecahall
Cirrus & Breeze
Feb 25, 2007 03:47 PM
