need help on 04 2.4 4cyl
the number 4 cylinder is getting oil in it just wondering if theres a gasket that keep the oil from geting in there or what going on i could use the help the car hat almost 100k miles on it thanks
Could be the valve stem seal(s) or the piston rings. Valve stem seals are more likely. They can be replaced without removing the cylinder head, but special tools are required.
If it's a piston ring problem, that requires a major engine rebuild.
How did you determine that there's oil getting in there?
the check engine light came on so i replaced the spark plugs aboy6k ago and there was oil on the number 4 sparkplug and now when theres a load on the engine it misfires bad and i just took the spark plug out and cleaned it about 1k ago then again today and it still has oil on it and i dont have waranty so im going to tdo the work myself if i can figure it out i got to drive it back home and thats 800 miles from my perants house it did good untill i hit about 600 miles after i cleaned it then it miss foires really bad in gear
ManuteSwol
May 13, 2012 07:20 PM
monique111
Jun 12, 2009 10:55 PM
