No HEat
Old Oct 16, 2009 | 02:05 PM
Dig's Avatar
Dig
Default No HEat
I have a 2001 Sebring Convertible. Mostly few problems but for reasons no apparent to me the heat is not working. I turn the **** all the way to the right (full heat) and nothing but cold air.
Any help appreciated
Old Oct 16, 2009 | 05:02 PM
Could be a couple things. If your coolant level is low, you may not be getting heat. Check that first. If it's low, you need to find out why. A leak somewhere?
Could be a plugged heater core.
Could be a faulty blend door in the heater.
Could be a faulty control head.
Are there any other symptoms? Like it blows from the defroster duct rather than anywhere else?
Old Oct 19, 2009 | 07:51 AM
Dig's Avatar
Dig
Thanks is was the low coolant. It looks like the thermostat housing may be leaking as it is lightly we around it.
It seems pretty easy to change maybe I will give it a go.
Old Oct 21, 2009 | 07:22 PM
If yours is a 2.7L then that thing on the top of the engine is not the thermostat housing, but rather is called the coolant outlet manifold. There are four bolts holding it in place, three are easy to get out. Browse around the forum to find some threads on the subject.
Old Oct 22, 2009 | 02:59 AM
ali22's Avatar
Congrats you got the solution of your problem.Its great t know that you are happy with the service.Whenever any problem occurs before that check it properly.
DJ SHORTY
Jan 14, 2020 05:49 PM
reyesraiders1
Nov 11, 2010 09:39 PM
davet
Dec 19, 2007 04:18 PM
stunod2002
Dec 15, 2006 03:27 PM
Petre
Dec 11, 2006 01:44 PM
