not shifting out of first
Old Jan 13, 2020 | 05:36 PM
fyshbyte's Avatar
Default not shifting out of first
2003 2.7 automatic 4 speed
not shifting out of 1st
works in drive but does not shift out of 1st
dash lights are lit up with all drives in boxes instead of just the letters P R D 1 2 3 4
Old Jan 13, 2020 | 05:54 PM
REBEL59's Avatar
Could be a couple of things...
First try disconnecting both the + and = battery cable ends, while off Clean the posts on the battery AND the cable clamps.
Then follow the =(negative cable) to the body AND down to the engine and clean them. Use dielectric grease at all connections to help prevent corrosion.
Second, Is the CEL light on also?... Need to get the code(s) stored in the computer that is turning on the dash CEL light and post them here so we can try and help figure out what is going on.
Old Jan 13, 2020 | 05:58 PM
fyshbyte's Avatar
thank you for the quick response
will get to it in the AM and get back to you with the info
Old Jan 13, 2020 | 06:01 PM
REBEL59's Avatar
IF CEL is on when driving the car...CODES MUST BE RETRIEVED BEFORE THE BATTERY GETS DISCONNECTED. Or they will be erased and you won't find any to work from.
Old Jan 13, 2020 | 06:23 PM
fyshbyte's Avatar
oops! disconnected terminals already
thx for the info
Old Jan 14, 2020 | 09:52 AM
fyshbyte's Avatar
attached terminals this morning and CEL lights are gone. car seems to run good. will do a thorough cleaning as you suggested
53,000 miles
I love my Sebring!
thank you for the advice
anwaypasible
Jun 22, 2019 05:07 PM
Townandcountrydad
May 19, 2017 12:57 AM
george3405
Apr 28, 2016 08:39 AM
Smb
Jul 28, 2013 08:36 PM
jvh24521
Sep 10, 2012 08:39 PM
