oil light keep blinking
Old Jun 28, 2008 | 09:58 AM
debbieking's Avatar
Default oil light keep blinking
Hi purchase a 1999 chrysler JXI convert. the oil light started blinking off and on . Check oil level it was low added to quarts okay for a day than it started blinking again. The blinking is not continous but it worries me. No manual in car at purchase.
Old Jun 28, 2008 | 02:26 PM
RobS's Avatar
Default RE: oil light keep blinking
It started blinking again, did you check the level again, your car has the 2.7 right, they are known for oil leaks
Old Jun 29, 2008 | 12:18 AM
bandaide's Avatar
The 99 is either a 2.4 L inline 4 cylinder or the 2.5L V 6. The V6 which is usually in the JXi will have a leak through the oil pressure sending unit coating the electrical connection and causing higher than normal resistance. This causes the light to come on at low (idle) speeds. Have the actual pump pressure tested using a gauge in the same place the switch is mounted (right above the oil filter) and replace the switch after cleaning the connections. It should go away although it may take a little time because the oil is extremely difficult to get out of the wiring.
Old Jun 29, 2008 | 04:35 PM
debbieking's Avatar
Default RE: service engien soon light
Thank for the information on the oil light. The service enigine light came on this morning on my way to work, got in my car at 3:00pm and non of the gauges or electric parts were working.window works and the radio and lights. Every thing else not working
Old Jul 2, 2008 | 09:35 PM
bandaide's Avatar
Since you're having what appears to be massive system failures, have the battery condition checked. It may be starting to fail to hold a complete charge.
debbieking
Nov 20, 2018 08:15 PM
Bman24
Jun 16, 2015 01:21 PM
Howard_Woodard
9
Apr 3, 2014 01:03 PM
GO PATS
Dec 11, 2012 08:53 PM
rowl3y
Mar 3, 2011 02:05 PM
