Oil in spark plug galleries
Old Oct 9, 2010 | 10:48 AM
SSJ's Avatar
SSJ
Default Oil in spark plug galleries
Had my 01 Sebring 2.4 DOHC for a little over a year now and decided to change spark plugs and wires. While swapping out the two center plugs, (cylinders 2 and 3), there was about an inch or inch and a half of oil sitting in the spark plug galleries. Any ideas as to how it got there? I'm thinking it is either the old plugs weren't seated tightly, or the top valve cover is somehow leaking into these plug holes. Is this a common occurance and/or am I into costly repair by a technician?
Old Oct 9, 2010 | 12:12 PM
on the valve cover there is spark plug tube seals u get new ones when U get a valve cover gasket set.
Old Oct 9, 2010 | 01:43 PM
SSJ's Avatar
SSJ
Thank you! So to replace the tube seals, I have to replace the whole valve cover gasket as a kit. Is this a big job with specialized tools, or can a knowledable backyard mechanic do it easily? I work for an aftermarket parts store and can do most of my own repair work. I've never taken the top off a DOHC before, but it doesn't look to complicated at first look. Anything I should watchout for? Or would you recommend a qualified tech do this job?
ScAndal
Feb 28, 2015 03:34 PM
NeonMan
Feb 23, 2014 10:14 AM
emhomes
Jan 19, 2014 05:42 AM
