overheating problem
Old Nov 3, 2011 | 01:43 PM
deefabo27's Avatar
Default overheating problem
I have a 2005 Chrysler Sebring Sedan Limited. When I turn on my heat, my car overheats. I was told that I needed a thermostat, but I dont know. Can anyone tell me what to do as far as getting this problem fixed? Or tell me how to fix it myself to save money?
Old Nov 3, 2011 | 02:25 PM
Laimon's Avatar
what engine do you have ? mileage ? are you losing coolant ?
Old Nov 3, 2011 | 03:24 PM
a broken or bad thermostat will not cause the car to over heat when u turn on the heat.
Old Nov 5, 2011 | 04:42 PM
deefabo27's Avatar
Its a 2.7L DOHC 24 Valve. It has roughly 107,400 miles. And when it overheats it loses coolant. Do I need a thermostat?
Old Nov 5, 2011 | 04:57 PM
There are many possible causes of overheating. Leaves and debris clogging the radiator, collapsed radiator hose, bad thermostat, coolant leak, inoperative fan(s), plugged radiator core, blown head gasket, wrong or weak or old coolant, bad radiator cap, etc, etc.
Check what you can. If you can't figure it out by yourself, get someone who knows what he's doing to look the system over. There are tests that can be run (coolant specific gravity, pressure tests) that can rule out some things. Nobody can do that over the internet.
moparnewby
Aug 23, 2010 07:15 PM
ptqueen79
Dec 30, 2008 02:56 PM
baseballchris05
May 7, 2007 07:38 PM
mykej27
Mar 12, 2007 09:22 PM
Morparth
Jun 19, 2006 10:04 PM
