Passenger window wont go up
Old Sep 14, 2008 | 07:06 PM
Kregerguy's Avatar
Default Passenger window wont go up
96 Sebring Lxi passenger window will not go upwith either the driver or passenger side button. it doesnt make any noise whan i press the button. the fuse is still good under the hood. the driver window works properly. what could it be?
Old Sep 15, 2008 | 06:36 PM
Attitude0917's Avatar
Default RE: Passenger window wont go up
Sounds like you need a new window motor. Just a guess, but if neither controls do anything, that would be the thing to look at. Did the window go up slow or have any issues before it quit working?
Old Sep 15, 2008 | 11:13 PM
Al B's Avatar
I would have to say the motor is pooched as well. You can buy just the motor if I'm not mistaken. Also, used, not abused, could be an option.
Old Sep 16, 2008 | 02:11 PM
You should check for voltage at the motor to verify the problem before replacing the motor. It could be a bad circuit breaker or relayor a broken wire rather than the motor. If you get voltage at the motor when pressing the switch, you should disconnect the glass from the regulator and move the glass by hand to be sure that it moves properly. If there's voltage and the glass moves easily by hand, then for sure it's the motor.
windex42
Dec 12, 2009 09:34 AM
reese
Jul 28, 2009 09:28 PM
dtoes91
Apr 29, 2009 04:34 PM
finlandmauri
Dec 26, 2007 09:39 PM
JimboXL
Jul 16, 2007 09:48 PM
