Power window motors
Old Feb 15, 2012 | 04:20 PM
Gasguzziler's Avatar
Default Power window motors
Well I have a 2005 sebring sedan and I am wondering what models I could get a window motor out of to work in my car. I have two motors that are either working sporadically or not at all and they have a couple 2003 sebrings at the local pic and pull but I am not sure what style they are. Any help is always appreciated.
Old Feb 15, 2012 | 10:26 PM
2001 thru 2006 Sebring Sedan or Dodge Stratus sedan should all be basically the same part. Coupes won't work. Are you sure it's the motor and not the switch or wiring? The driver's door wiring is kind of notorious for breaking near the hinge due to flrxing.
Old Feb 16, 2012 | 10:20 AM
Well I am perty sure it is the motor on the rear pass side window being it will go down about an inch or so if you hit the switch but will only go up with assistance, I am going to have to look harder into the drivers side one though being it is more of a sporadic worker and it may be the wiring.
Old Feb 16, 2012 | 12:40 PM
teddysmith1952's Avatar
Yes, I would recommend looking at the wiring in the door boot. The fact that it's "sporadic" makes think otherwise unless the stranded wire is nearly all separated and is arcing..I had a driver side power door lock that would not work at all and the prob was a broken wire in the door boot. As dcotter0579 mentioned these thin gauge wires are notorious for breaking with all the stress they receive from the opening and closing of the doors...Good luck.
Joey-D
Jan 6, 2019 12:34 AM
ntwrkguy1
Oct 8, 2012 10:21 PM
flexogreen
May 24, 2010 10:59 PM
c13ckb
Dec 21, 2009 02:54 PM
aleatha_0814
May 11, 2005 01:58 AM
