Problem with bolt on 02 sebring 2.7 convertible control arm
Changing out the lower control arms on 02 sebring limited. got the passenger out but on the drivers side I have one horizontal bolt that is loose but hitting the transmission and wont let it come out to free the bushing for the control arm. Here is a link to show the problem, It is in spanish but doesn't explain how to fix it. does anyone know what has to be done to get the bolt out?
I have not tried that. do you know how many i will have to unfasten? I was gonna put a jack under transmission and at least take that mount out. Is it not feasible to lower subframe? hated messing with trans and engine.
fyi, I had to loosen motor mount and jack up tranny about an inch, then had to lower subframe about a half inch, and finally used dremel to notch out a bit of the bolt flange and voila. I don't know if it was text book, but it got the job done.
hjsn1@hotmail.com
Dec 5, 2019 09:06 PM
Dmkrohl13
Sep 16, 2016 06:08 PM
simon142
Sep 30, 2014 02:10 PM
chrisaprice2000
May 30, 2012 07:19 PM
