Programming 3rd Transponder key
Old Sep 5, 2009 | 06:52 AM
ShutEyeThinkin's Avatar
Default Programming 3rd Transponder key
Hi all,
I have a 2004 Chrysler Sebring convertible. I have two working transponder keys. I bought a 'blank' transponder key on eBay ($17). I am having trouble with the sequence required to program the 3rd new key.
I am following the instructions in the 2004 manual, and have found other very similar programming sequences on the net. I think the main problem is getting the car into 'Programming Mode'.
On page 10 in the manual there is a section on 'Customer Key Programming'. It states (and I quote):
"Customer key Programming
You can program new keys to the system if you have two valid keys by doing the following:
1. Insert the first valid key into the ignition and turn the ignition On for at least 3 seconds but no longer than 15 seconds.
2. Insert the second valid key and switch the ignition On within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash.
Turn the igniton Off and remove the second key.
3. Insert a blank Sentry Key into the ignition and switch the ignition On within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off.
The new Sentry Key has been programmed. Repeat this process to program up to a total of 8 keys."
I think the problem is in Steps 1 and 2. In Step 2, I always get a double chime rather than a single chime, but the Theft light flashes continuously.
I've tried many different timing sequences and nothing seems to work.
Has anyone had trouble programming a new key? Any suggestions?
Thanks,
ShutEyeThinkin
Old Sep 5, 2009 | 04:44 PM
I say its the key u got
Old Sep 5, 2009 | 09:25 PM
Default Other possibilities
It could be that a previous owner(s) already programmed the maximum number of keys (8) and you can't program any more keys. This is more likely if your car was once in a rental fleet. Another possibility is that you are holding the keys too close together when programming. They can confuse each other if they are too close together.
415Pac
Apr 23, 2010 02:19 PM
user35007
Dec 13, 2009 11:44 AM
firefly
Dec 7, 2008 05:16 PM
MoonShadow
Mar 18, 2008 01:07 PM
tfgib
May 12, 2007 07:58 PM
