Pulls left when accelerating
Old Feb 3, 2013 | 07:59 PM
02 Limited Conv's Avatar
Question Pulls left when accelerating
02 Sebring Limited Conv pulls slightly to the left when traveling down the road and you accelerate.
Five thousand miles ago the front struts and coil spring bushings were replaced. All the suspension nuts and bolts are tight.
Had wife sit in car and crank it up to see if I could spot any unusual shift of suspension with car in the air. Saw nothing unusual.
Can anyone tell me what I need to do to correct this situation?
Thanks in Advance.
Old Feb 4, 2013 | 03:02 AM
Shadowed's Avatar
Maybe one wheel is braking ? Check after some driving, might be very hot. But if you say that something was done to springs and and stuff it is very likely that wheels are not aligned correctly.
Old Feb 4, 2013 | 09:41 AM
Check the tie-rod ends, especially on the right. A worn ball joint there would allow the right front wheel to steer left with acceleration.
Ch51sez
Aug 2, 2013 09:38 AM
wtroger
Mar 7, 2013 02:59 PM
Csherwood
Apr 20, 2008 07:14 PM
97K15004WD
Aug 26, 2007 07:35 PM
Jan 8, 2005 07:51 PM
