Rad fans always running
Old May 15, 2008 | 03:19 PM
seawind3000's Avatar
Default Rad fans always running
My rad fans are running whenever the engine is running. When I start the car, 30* out side temps (01 convtertible) the fans are on HI, if I remove the HI fan relay , they run on low untill I remove the low fan relay. The AC is toped up and works fine. This happens when the heater is on so it's not the AC demanding the extra cooling. Any help would be great.
Mike
Old May 16, 2008 | 08:53 AM
moe's Avatar
moe
Default RE: Rad fans always running
hey mike there is also the coolant temp sensor that controls that circuit.check it out see if its not shorted .(greeen stuff growing on wires) also the pcm .do you have codes?
Old May 16, 2008 | 07:28 PM
I'll check for the codes in the am.
Thanks, Mike
Old May 16, 2008 | 11:44 PM
irdaneel's Avatar
In addition to your temp sensor and associated wiring, and your pcm, your a/c controls can also call for the fans to run. (Assuming there is a malfunction in that system.)
Lenny
Sep 4, 2012 10:30 AM
95ImpySS
13
Aug 23, 2011 12:42 PM
rich8363
Jan 31, 2010 10:53 PM
plen123
Aug 10, 2008 04:37 PM
davidandkeiley
9
Jun 4, 2007 07:07 PM
