replace belt on '10 2.4
Old Jun 4, 2017 | 10:27 AM
Cory Cuneo's Avatar
Default replace belt on '10 2.4
Just opened the hood on my daughters Sebring looking to change the serpentine belt. But,,,, cant for the life of me find a tensioner pulley or similar? So how exactly do I loosen this thing so I can get it off and on? Googled it but cant seem to find the right year,,, Thx Cory
Old Jun 5, 2017 | 09:50 AM
Lug's Avatar
Lug
If it's anything like my 2010 2.7L , the tensioner sits between the crankshaft pulley and the alternator pulley, in between them, but above both. (so the three create a triangle).
You need to remove the RH wheel well splashguard. Look for the smallest pulley of the bunch there.
You need to place a ratchet/box end wrench and move the pulley counter clockwise in order to release the tension on the belt.
Old Jun 5, 2017 | 01:43 PM
Cory Cuneo's Avatar
Thank you, and Im guessing the wheel has to come off also?
Old Jun 5, 2017 | 01:45 PM
Lug's Avatar
Lug
yup.
if you're new to this, don't work under a jack only, purchase jack stands and support the car from the front of the pinch rail.
Old Jun 5, 2017 | 01:48 PM
Lug's Avatar
Lug
This is from a 2.7L motor drawing, yours may vary, I'm not sure. But if they are the same, #7 is what you're looking for.
Old Jun 5, 2017 | 06:00 PM
Cory Cuneo's Avatar
Thx for the photo, have to be honest, will look again but didn't see anything like that #7, I mean its a pain to see with the transverse mounted engine but that "wheel" should have stood out I think.
Old Jun 5, 2017 | 06:08 PM
Lug's Avatar
Lug
As long as Google is not ****ting it, here's an actual image of a 09 2.4L
In this image, it appears to be #2.
BTW, in some vehicles there's a diagram of the serpentine belt routing, on the bottom side of the hood.
Old Jun 18, 2017 | 12:25 PM
esu's Avatar
esu
OK, sorry for the delay, got caught up in 7 other projects, this diagram is not the motor in her car. She has the 3 smaller pulleys but they are clustered on the right side in between the ac compressor on the bottom and the ps pump on the top or 3 and 4 in the diagram. None of them are on a swing arm type of assembly, it appears they all bolt directly to the engine?? The bottom one I cant see that clearly, maybe there is some type of adjustment on it?
Old Jun 18, 2017 | 01:00 PM
Lug's Avatar
Lug
To remove all doubt, in this case, I'd either buy a Chilton manual, or even better - get an AllDataDIY subscription for your exact car model, about $30 for 5 years.
That, will tell you exactly how your engine is set up, and leave very little doubt.
It's either that, or Google (sometimes you just can't find the right answer), or for someone with the similar motor as yours to reply.
embalmerjeff
Sep 29, 2015 05:36 PM
jam3700
Dec 1, 2011 02:53 PM
bowlingss
12
Mar 9, 2011 06:58 AM
zerodock
Jul 2, 2005 10:43 PM
